CALI-CALI
Oct 18, 2016Aspirant
RN104 6.6.0 firmware issue
After installing the latest 6.6.0 firmware, uploading, deleting or dragging and dropping a file in a folder hides all files folders in the share anfd the only way I found to access them again is by r...
- Oct 21, 2016
Hello CALI-CALI,
Are you accessing the NAS via web browser using HTTP/S access? If so then you must have forwarded 443 port. If you are just remotely accessing the NAS then it is not a good idea to troubleshoot it that way. You have to be with the NAS for troubleshooting.
By the way, have you checked if you get the same problem when you are connected to another network and using web browser?
CALI-CALI
Oct 21, 2016Aspirant
Hello JennC.
I'm not using ReadyNAS in this specific case as I find it faster to connect directly to the NAS.
I'm using the default NAS port can't recall now but will tell you Sunday when back).
I access my router remotely via port forwarding features, specifically port 8104 is opened and routed to the proper NAS port.
This procedure was fully working before release 6.6.0. Now workks but simply the shares page does nit show the diectory trees under each share unkess the system page is reloaded.
Regards
CALI
JennC
Oct 21, 2016NETGEAR Employee Retired
Hello CALI-CALI,
- CALI-CALIOct 21, 2016Aspirant
Dear JennC,
thank you for the advice. I have tried connecting through another network and it works.
I don't understand what might have caused the issue but it's not important anymore.
Regards
CALI
- JennCOct 21, 2016NETGEAR Employee Retired
Hello CALI-CALI,
I am glad you were able to isolate the problem and found that it is the network where it was connected.
Please feel free to post suggestions, comments and questions as we value your feedback and contribution to the community, thank you!
