Jeff_D
Feb 14, 2016Aspirant
RN104 crashed with kernal seg-fault or ???
HI, My RN104 stopped communicating and after I verified that it was ON but not answering I looked at the front display and all the unit said was do_exit+8d8. It was non-responsive to the power butto...
HelloGear
Apr 05, 2016Aspirant
I disable and re-enable the Secure Diagnostic Mode.
My RN104 is behind an ordinary router, which I think provides some level of firewall in a normal way.
HelloGear
Now I recognized that the Secure Diagnostic Mode is disabled again for some reason.
I suppose enabling Secure Diagnostic Mode lasts only for several hours.
I re-enabled it now.
- mdgm-ntgrApr 05, 2016NETGEAR Employee Retired
Please power off the system and try booting it again and see if subsequent shutdowns work fine.
- HelloGearApr 06, 2016Aspirant
Now the system boots up normally. Thank you.
However, shutdown process still gets stuck with the same error message "do_exit+8d0". I tried a few times. It happens every time.I have just re-enabled Secure Diagnostic Mode so that you can connect.
