Tensu
Jul 13, 2014Aspirant
RN104 Expansion
Hi, I have an RN104 that I would like to expand my volume on. I'm running OS 6 on it with 1 volume and one 4TB disk. It's currently in X-raid (RAID 1). Is there a way of changing it to RAID 0 wi...
Tensu
StephenB wrote: You are better off with jbod - when you use RAID-0 to span multiple drives, then when any drive fails you lose the entire array.
Ok, I did not think off that.
Can I change it to RAID-5 later when I get a 3rd drive without data loss, so I get some safety if one drive fails?
TonV wrote: Move to flex RAID first (turn off X-RAID), then add your disk. And like StephenB suggests, why not have 2 volumes with 4 TB instead of one with 8?
I dont know, I just want max performance for 2 drives untill I get a 3rd drive.
For the time being I just need more space on my existing volume.
