Whompin105
May 16, 2021Aspirant
RN104 fw:6.9.0 fail startup after RAID expansion
Had 3x 4TB drives and was getting close to hitting capacity. Added a 4th 4TB drive and waited a couple days for resync. At some point I saw RETRY STARTUP, and cannot power off without pulling plug....
- May 19, 2021
Whompin105 wrote:
Any ideas about what might cause the non-fresh disk being kicked from the array?
Non-fresh means it's not in sync (meaning some writes never made it to the disk). So the real question is why it's not in sync. Was the NAS forcibly shut down before this (or suffer a power failure).
It is possible to force the array to assemble anyway. Though being out-of-sync could result in some file system corruption/loss.
Whompin105
May 17, 2021Aspirant
I really appreciate the reply. Thank you.
Ok, so I looked at smart_history and can see one of the drives had 8 pending sectors, 8 uncorrectible errors and 9 ata errors, which were all logged after the 4th drive was added (horizonal expansion) and failed boot. I also used boot menu disk check before getting your response and it indicacted errors with disk1. I removed disk 1 and can get the device to boot and let me in to the admin page. RAIDar indicates an inactive RAID5 data-0 volume with 10.9 of 10.9 TB used (actual data i risk losing is about 7TB) and innactive "RAID level unknown" data volume with 0MB of 0 MB used. Admin page says to remove innactive volumes to use disks #2, 3 and 4. Was prompted for firmware update to 6.10.4, after which point the device will now boot with all 4 drives installed, but still shows inactive volume. It seems the updated firmware allows it to finish booting and detects the disk errors rather than freezing up, so now Admin page shows "remove innactive volumes to use disk #1,2,3,4." Anything else I can look into from here? I'm not in a position to pursue paid data recovery, but would happily spend a bit of time trying out other options and learning some things in the process.
May 18, 2021Guru - Experienced User
can you copy/paste mdstat.log into a reply here?
- Whompin105May 18, 2021Aspirant
Personalities : [raid0] [raid1] [raid10] [raid6] [raid5] [raid4]
md1 : active raid10 sdd2[3] sdc2[2] sdb2[1] sda2[0]
1044480 blocks super 1.2 512K chunks 2 near-copies [4/4] [UUUU]
md0 : active raid1 sdd1[7] sdc1[4] sda1[6] sdb1[5]
4190208 blocks super 1.2 [4/4] [UUUU]
unused devices: <none>
/dev/md/0:
Version : 1.2
Creation Time : Tue Aug 19 04:37:49 2014
Raid Level : raid1
Array Size : 4190208 (4.00 GiB 4.29 GB)
Used Dev Size : 4190208 (4.00 GiB 4.29 GB)
Raid Devices : 4
Total Devices : 4
Persistence : Superblock is persistentUpdate Time : Mon May 17 15:46:29 2021
State : clean
Active Devices : 4
Working Devices : 4
Failed Devices : 0
Spare Devices : 0Consistency Policy : unknown
Name : 0e3603c2:0 (local to host 0e3603c2)
UUID : 5fea52a3:c212a53f:5d24e9bb:6426d7ec
Events : 69127Number Major Minor RaidDevice State
4 8 33 0 active sync /dev/sdc1
7 8 49 1 active sync /dev/sdd1
5 8 17 2 active sync /dev/sdb1
6 8 1 3 active sync /dev/sda1 - Whompin105May 18, 2021Aspirant
I have tried to and my response post keeps disappearing - let's give it another shot:
/dev/md/0:
Version : 1.2
Raid Level : raid1
Raid Devices : 4
Total Devices : 4
State : clean
Active Devices : 4
Working Devices : 4
Failed Devices : 0
I have tried to, but whenever I reload the page the reply post disappears. I've tried sending it in a PM
- StephenBMay 18, 2021Guru - Experienced User
This tells us that the OS partition has expanded to all four disks. It's not clear why the horizonal expansion failed.
The volume is likely out of sync at this point, but there could be other things wrong.
Have you ever used the linux command line interface?
There is an automatic spam filter that sometimes kicks in. Periodically the mods review the quarantine queue and release false positives.
I can also release them, so you can PM me if it happens again.
I'm fairly comfortable on a Linux terminal, but haven't used the CLI to interface with the Netgear NAS before. It looks like I can SSH into the NAS as root, but I haven't played around enough with btrfs to know where to start diagnosing the filesytem.
