BeatWax
Sep 23, 2017Aspirant
RN104 Permissions denied and unable to change settings
Hi there, I have 2 identical RN104 units, same drives, same data, same firmware version (latest) however one of the units has recently stopped allowing any changes to data or settings. Trying...
Sep 23, 2017Guru - Experienced User
Are you seeing anything that suggests the volume is mounted as read-only?
BeatWax
Hi Stephan,
Not at all - all shares are clearly labelled as read/write in the file browser of web UI. Looking through macOS get info I can see that all user have read write access.
Not having the ability to change any setting - especially enable SSH suggests something more sinister that just access to data being the issue.
I have just tried reinstalling the OS via the boot menu but no change in behaviour.
- StephenBSep 23, 2017Guru - Experienced User
BeatWax wrote:
Not at all - all shares are clearly labelled as read/write in the file browser of web UI. Looking through macOS get info I can see that all user have read write access.I think you misunderstood me. If the NAS finds an issue with the volume, it will sometimes mount it read-only. The settings for the shares would still say read/write (but you wouldn't be able to write anyway).
Try looking at the volume settings page, and maybe at the log zip file.
- BeatWaxSep 23, 2017Aspirant
Right then... Nothing listed in the volumes page or the settings. I have looked through the volumes.log file and do not see any errors reported.
Is there another log file I should look at?
