chiki_munze
May 03, 2016Aspirant
RN104 SMB, spin-down, booting issues and possible solution for power efficiency
Hello to all, I was using for about 6 years ReadyNas Duo (Sparc). Due network speed and fan noise but very good realibility I wanted to upgrade to another ReadyNas familiy member and got RN104 OS ver...
mdgm-ntgr
May 04, 2016NETGEAR Employee Retired
- If you are running services that are using the disks then the disks won't be able to stay spun down. Also the OS is mirrored across all the disks so disk spin down will likely spin down all or none of the disks.
- What sync and what file scanning? Can you provide more details.
- Which services are you running under System > Settings > Services ? Also which apps are you running?
- Can you send in your logs (see the Sending Logs link in my sig) noting roughly when this happened?
chiki_munze
May 13, 2016Aspirant
Logs sent.
2. After every shutdown and power off, RadyNas 104 will scan all files on shares. You have it in logs.
3. smb, itunes, readydlna, rsync, upnp, http, https, ssh
4. sent
Thanks
