daKlone
Oct 21, 2024Aspirant
RN104 Stuck at "Booting..."
My old faithful RN104 running f/w 6.10.9 has encountered a problem which I need some help with: Initially, it sat say "Booting..." indefinitely (no percentage bar appears). All 4 drive lights ar...
Oct 21, 2024Guru - Experienced User
daKlone wrote:
Tried to do a firmware reset via USB, but it asked me to Telnet into it for debug and wouldn't accept the root password I'd previously set and now I can't SSH to it any more.
Can you log into the web ui?
If you can, then download the full log zip file and look in there for clues.
daKlone wrote:
df -h showed plenty of disk space available however.
Generally you need to use btrfs commands to determine the actual free disk space on the volume.
