desm11
Jan 05, 2015Aspirant
RN104 with 6.2.2 permanent freeze. How go back to 6.1.x?
Hi there, maybe someone solved a problem with permanent freeze of RN104 after upgrade to 6.2.x? Behavior: After Boot RN104 may work 1-2-3 days and stop responding. Device reply to ping, but no ...
IanWilson
Jan 08, 2015Aspirant
Well, much relief on my front. Netgear support came through after 12 hours or so and fixed my problem. Turns out that the procedure to uninstall some apps is broken and leaving some files behind which then interfere with the Apache server in the box. They advise not to uninstall any more apps until the firmware gets fixed. I am running 6.2.2 - could this be a similar problem you are having?
- Jan 17, 2024Retired_Member
