desm11
Jan 05, 2015Aspirant
RN104 with 6.2.2 permanent freeze. How go back to 6.1.x?
Hi there, maybe someone solved a problem with permanent freeze of RN104 after upgrade to 6.2.x? Behavior: After Boot RN104 may work 1-2-3 days and stop responding. Device reply to ping, but no ...
mdgm-ntgr
Jan 31, 2015NETGEAR Employee Retired
Can't give an ETA yet on when the next firmware will be available. In any case if an issue is hard to reproduce it is impossible to suggest a time on when there will be a fix.
Can you send a fresh set of logs (see the Sending Logs link in my sig)?
- Jan 17, 2024Retired_Member
