desm11
Jan 05, 2015Aspirant
RN104 with 6.2.2 permanent freeze. How go back to 6.1.x?
Hi there, maybe someone solved a problem with permanent freeze of RN104 after upgrade to 6.2.x? Behavior: After Boot RN104 may work 1-2-3 days and stop responding. Device reply to ping, but no ...
hactic
Mar 18, 2015Aspirant
Hi all,
same problem here on my RN104, using 1 TB WD and 2 TB WD Red in bay 1 and 2 for quite a while.
Freeze keeps occuring since January 2015 = after upgrading to OS 6.2.2.
Only unplugging helps. No suspected activity or apps (but only the OS itself).
Can I go back to 6.1.9 [http://kb.netgear.com/app/answers/detail/a_id/25636/~/readynas-os-version-6.1.9] by downloading and flashing it in?
I have a backup on a btrfs disk and am OK with losing the data on volume 1; also have done a factory reset already.
Any news on replicating the issue in the lab?
New version 6.2.3, 6.3.0 of the OS ahead?
best regards
Klaus (hactic)
best regards
Klaus (hactic)
- Jan 17, 2024Retired_Member
