desm11
Jan 05, 2015Aspirant
RN104 with 6.2.2 permanent freeze. How go back to 6.1.x?
Hi there, maybe someone solved a problem with permanent freeze of RN104 after upgrade to 6.2.x? Behavior: After Boot RN104 may work 1-2-3 days and stop responding. Device reply to ping, but no ...
mdgm-ntgr
Mar 21, 2015NETGEAR Employee Retired
# cd /root
# wget url
# echo /root/ReadyNASOS-6.2.2-arm.img > /etc/.flash_update
Note if you download a zip file you will need to unzip it
# unzip filename.zip
- Jan 17, 2024Retired_Member
