Laserbait
Oct 07, 2016Luminary
RN204 upgrading from 6.5.1 to 6.6.0
Hello, I logged into my RN20400 today, and I see that there is an update to 6.6.0 available. The RN20400 is prompting me to upgrade from 6.5.1 to 6.6.0: But in the release notes it says ...
- Oct 07, 2016
Laserbait wrote:
Is there a way that this can be confirmed? I'd rather not brick my RN20400. :)
If you are worried, just install 6.5.2 first. You can manually download it from here: http://kb.netgear.com/app/answers/detail/a_id/31116/~/readynas-os-version-6.5.2?cid=wmt_netgear_organic
Extract the image file from the zip, and manually install the image file from settings->install firmware
Laserbait
Oct 07, 2016Guru - Experienced User
- mdgm-ntgrOct 07, 2016NETGEAR Employee Retired
6.6.0 does not contain upgrade code that is required for upgrading ARM systems from 6.3.x or earlier. Any ARM system on 6.4.x or later would not be bricked updating to 6.6.0.
In any case if someone did try an upgrade direct from 6.3.x or earlier it should be fixable, but best to avoid this.
