milind2021
Apr 15, 2021Aspirant
RN212 act as switch using 2nd ethernet port
I am wondering if I can use my the 2nd ethernet port of my readyNAS as an additional port to occasionally connect my laptop or my 100Mbps-connected Wifi AP (so plenty of headroom there). I guess thi...
Apr 15, 2021Guru - Experienced User
Is this possible?
If your goal is to reach the internet (or other devices on your home network) over that connection, then that won't work.
It's better just to buy an small switch.
- milind2021Apr 19, 2021Aspirant
Agreed it's easier, but it adds unnecessary clutter.
Can it not become a supported option? I think you'll find a lot of users would appreciate it.
- StephenBApr 19, 2021Guru - Experienced User
This is a customer forum, and I don't work for Netgear.
You can post it in the idea exchange if you like. https://community.netgear.com/t5/ReadyNAS-Idea-Exchange/idb-p/idea-exchange-for-storage.
- SandsharkApr 19, 2021Sensei
It's do-able from SSH. See here: https://wiki.debian.org/BridgeNetworkConnections .
Generally speaking, it's usually a bad idea, so I would vote against it as an option because those not recognizing the down side might choose to use it. The switch solution StephenB suggested is far from "unnecessary clutter". It performs the task you need without putting a load on the NAS processor or even requiring the NAS to be on. And the processor on a 212 isn't particularly powerful, though better than some earlier models. The switch and single additional cable you'll need can be purchased for about $20US. A 5-port switch is quite small, though you do need to be sure your're not power receptacle challenged.
