MarkMills
Sep 08, 2024Follower
RN214 Fan Question
Hello All, I see questions here about fans and noise, etc. I am not as worried about those issues as the NAS hides in the basement next to the switch. The question I have is can the voltage be...
Sep 09, 2024Guru - Experienced User
MarkMills wrote:
I'm running 4 10TB HGST 7200 RPM drives. Day to day, the outside drives are at about 39 degrees, the inside 2 are about 35 degrees.
This is a completely normal temp range, so not something I'd be worried about.
My own NAS drives (10 TB WD Plus) are running between 35-44C at the moment, with the NAS cooling set to "balanced". The outlier (44C) is air-filled, the others are helium, and I suspect the air-filled model might be designed to run a bit hotter. It also is in a basement.
