profeta64
Nov 24, 2020Luminary
RN214 OS6.10.3 Webgui hanging during scheduled operations
I have currently since several hours my RN214, with 2x WD Red 3TB discs which is doing something, I suppose an antivir scan, and both web interface, samba share and Plex not accesible... I do not ha...
profeta64
I was able to get back in the WebUi...for a short time... :|
Seems it had a restart thus I was able again to log in.
I extracted the relevant logs.
| Nov 24, 2020 11:08:40 PM | System: ReadyNASOS background service started. | |
| Nov 24, 2020 11:08:16 PM | System: ReadyNASOS service or process (sysadm) was restarted. | |
| Nov 24, 2020 05:40:30 PM | System: Antivirus scanner definition file was updated to 59.25998. |
| Nov 23, 2020 06:46:55 PM | System: ReadyNASOS background service started. | |
| Nov 23, 2020 06:46:39 PM | System: ReadyNASOS service or process (snapshot_monito) was restarted. | |
| Nov 23, 2020 05:39:57 PM | System: Antivirus scanner definition file was updated to 59.25997. |
| Nov 21, 2020 06:18:58 PM | System: ReadyNASOS background service started. | |
| Nov 21, 2020 06:18:42 PM | System: ReadyNASOS service or process (continuous_snap) was restarted. | |
| Nov 21, 2020 05:52:52 PM | System: ReadyNASOS background service started. | |
| Nov 21, 2020 05:52:41 PM | System: ReadyNASOS service or process (enclosure_monit) was restarted. | |
| Nov 21, 2020 05:37:42 PM | System: Antivirus scanner definition file was updated to 59.25995. |
Nov 25, 2020Guru - Experienced User
Is there any explanation for the restarts?
Does the volume resync after the restarts?
- profeta64Nov 25, 2020Luminary
The issue comes from clamav.
After SEVERAL tentatives, I was able to get access to the WebUI, enable the SSH termina.
Then after other several tentatives, and timeouts I was in the prompt...
I used then
ps -eo pid,ppid,cmd,%mem,%cpu --sort=-%mem | head
to get the process list, and the clamav process was eating most of the ressources (~92%).
Plex instead was around 1%.
Now I disabled the antivirus functionality, and I did not observed any hanging since 24h.
In the log file there is no information about volume resync...
Where I can get it?
- StephenBNov 25, 2020Guru - Experienced User
Where I can get it?
Look for "resilver" in the === maintenance history === section at the end of volume.log
profeta64 wrote:
I used then
I suggest checking the fullness of the root partition. It's only 4 GB, and the system will misbehave in several different ways if it is getting full. Normally it's around 25% used.
The last resilver happend in February 2020...
The root partitin seems not to be a issue...
/dev/md0 3862208 1511520 2124796 42% /
It is perhaps a little higher than you are expecting..
