Redescort87
Aug 24, 2018Follower
RN214 ReadyNas is stuck on maxed out drive capacity
I have a readynas 214. I am using this as a backup solution and while backing up data it became full. I cleaned off space and tried again but the backups kept failing. I logged into the nas portal an...
JohnCM_S
Aug 24, 2018NETGEAR Employee Retired
Hi Redescort87,
Welcome to the Community!
Can you download the system logs and then provide it to us? You may check this link on how you can send it.
- JohnCM_SAug 28, 2018NETGEAR Employee Retired
Hi Redescort87,
Were you able to send the logs? You may just send it to us so we can further check the issue. Please check the link I have provided on the previous post on you can send it.
