paffendorf
Oct 13, 2021Follower
RN3138 No IP after outage
Dear friends, i have a problem when for any reason i have an outage at home. When the power comes back on, routers, switches and the nas itself start booting up. After everything is back to norm...
DEADDEADBEEF
Oct 13, 2021Apprentice
Could probably achieve it by making some changes to systemd but a better solution to consider is to set a static IP on your NAS, you likely want NAS to always have the same IP so you might as well set it manually. Add a reservation on DHCP server to avoid it giving out the IP to someone else and causing a duplicate IP.
- StephenBOct 13, 2021Guru - Experienced User
Another option is to protect the NAS with a UPS, so it will retain the DHCP IP address. I always recommend a UPS for NAS anyway, since lost writes due to unclean shutdowns can result in data loss.
Personally I also protect some of my switches (and the router), which keeps my internet service working through short outages.
- SandsharkOct 13, 2021Sensei
I also wonder if you are really gaining anything with the LAG configuration, which I'm guessing is at least a part of the cause since the NAS will not normally behave that way when there isn't one. What is the status of the LAN LEDs on the NAS when it's not communicating?
Yeah. Connecting the NAS directly to the router would also probably solve it, and that probably requires giving up LAG. The NAS will of course request a DHCP address when it boots, but also when the ethernet link comes up.
What is likely happening here is that the router is booting up last. The NAS isn't getting the DHCP address when it boots, because the router isn't up. The NAS sees no change in ethernet link status when the router does finish booting, because the switch is masking it.
