gpaolo
Dec 05, 2015Luminary
RN314 - Upgrading disks
Hello, I have a RN314 with already four driver, 2x1TB and 2x512GB. Each pair of disks is in RAID1 (apparently flex-RAID, I guess) mode. I'm about to upgrade the 2x512GB drives with 2x4TB WD RED d...
- Dec 05, 2015
There's no need to turn the NAS off. You can remove one of the 512GB drives with the system running, and hot-insert the replacement. After the rebuild completed, so the same with the other one.
Another option is to copy the data temporarily, destroy the 512 GB data volume, remove both the old drives and insert the two new ones. Then create a new RAID-1 volume.
Dec 05, 2015Guru - Experienced User
gpaolo
Thank you very much Stephen!
