Winnebago1
May 28, 2017Tutor
RN314 6.7.2 to 6.7.3 or 6.7.4 upgrade issues
I, too, have had major issues upgrading from 6.7.2 to 6.7.3 or 6.7.4. Please note that I am running an external enclosure. If I upgrade with the external enclosure powered up, I get endless loops o...
- Jun 09, 2017
You've got an EDA500. Have a read of the 6.7.5 Beta 1 Release Notes and if you think you've run into an issue mentioned there you may wish to go to https://ip.address.of.nas/fwbroker and update to the beta.
mdgm-ntgr
May 28, 2017NETGEAR Employee Retired
If you look under the hood our OS is based on Debian Jessie and the kernel is based on the 4.4 LTS kernel series with backported patches. We're ahead of at least most of the competition in this I believe.
Our experience with BTRFS is much greater than most too as we've been using it for all our new products since 2013 as the default and only filesystem for the data volume (and for the root volume as well on x86 systems).
If there's features you'd like to see added you can post them or upvote them in the Idea Exchange for ReadyNAS
It would be good if you could send in your logs (see the Sending Logs link in my sig).
You may have also got a core dump (/var/cores/core-readynasd) which would be useful for debugging the issue you encountered.
pollensteyn
Jun 09, 2017Aspirant
I'm in the same boat. Upgraded from 6.6.1 to 6.7.4. Volumes are up, system reachable through ssh, but admin page is offline. Readynasd is restarting every 15 secs.
What would the first step be: firmware reinstall?
Thanks
P
- mdgm-ntgrJun 09, 2017NETGEAR Employee Retired
- pollensteynJun 09, 2017Aspirant
That seems to be doing the trick, thanks! Admin page is up, nothing unusual to been seen for now. I have to say though that I'm always very reluctant to upgrade this OS6 box, ran into serious trouble in the past. I never had any issues upgrading my NVX Pioneer, different OS though.
Cheers
P
- Winnebago1Jun 09, 2017Tutor
That did the trick for me as well. There was nothing in the release notes to indicate what changed that may have fixed it. I am good to go right now.
Thank you, MDGM!- pollensteynJun 10, 2017Aspirant
Well, the changelog (#3) mentioned 'Fixed "Management service offline" issue, with an EDA500 unit attached and an orphaned volume record.' That was one of visible symptoms I noticed (the 'Management service offline' message in Raidar) . From the logs I could not make a direct connection with the EDA500 attached to my 312 however.
Regards
P
