ulfrickardsson
Oct 27, 2015Aspirant
RN314 add's .1.
Hi I am using RN314 and I am doing backup to dropbox using the function inside RN314. RN314 creates copy’s of some files and adds .1. at the end of the filename. Why? And how can I prevent this to ...
ulfrickardsson
Oups, its a 314
Firmware 6.2.4 time is correct
JennC
Oct 27, 2015NETGEAR Employee Retired
Hello ulfrickardsson,
Are those with ".1" in the filenames are duplicate copy?
Maybe you can check if there are more than one computer that has this same files and syncing with ReadyNAS via DropBox too.
- ulfrickardssonNov 03, 2015Aspirant
Yes, its exactky the same file
Nope, no computer syncing at all, only the rn314 syncing.
Also I have discovered that when rn314 backups a file to dropbox it changes the date for the file at the rn314.
