kenalker
Feb 11, 2015Aspirant
RN314 and the Recycle Bin
I can not figure out how to enable the Recycle Bin feature on my new RN314. I was using it on the NV+.
Mar 15, 2015Guru - Experienced User
MAC text files are compatible with linux, so textedit should work. I think the normal "compress" will create a compatible zip (I'm not a mac user, so I am not sure exactly how to do this, or if there is a simpler way. Perhaps try dragging the updated file into the zip, and see if it takes.
Its always a good idea to have a backup, but particularly important to update them if you are messing about with the configuration or disks.
