Afiorai's avatar
Afiorai
RN314 Upgrade From 6.2.0 to 6.2.1 No Problems
This is just to supply a bit of visible feedback for anyone still waiting to update.
I have an RN314 and applied the update to OS6 6.2.1 from 6.2.0 on 21 Dec, 2014 and so far all is normal. No issues yet discovered. All shares are visible and accessible.
  • Did you already reboot after upgrading? That were the problems started for me.
  • My reboot took a long time - in the end (over an hour) I had to turn it off, then it booted fine.
    Also, has anyone tried uninstalling an app? I lose Dashboard when I try to uninstall some apps, so you may wish to enable ssh before trying.
    viewtopic.php?f=153&t=79147
    Yes. To add to the info, I pressed the "Upgrade" button on the FrontView UI to start the upgrade then selected the reboot option afterward. The NAS rebooted and connections were re-established.
    So, in other words, I didn't do anything special with the process.
ProSupport for Business
