Afiorai
Dec 22, 2014Aspirant
RN314 Upgrade From 6.2.0 to 6.2.1 No Problems
This is just to supply a bit of visible feedback for anyone still waiting to update. I have an RN314 and applied the update to OS6 6.2.1 from 6.2.0 on 21 Dec, 2014 and so far all is normal. No iss...
ReadyJabba
Dec 22, 2014Tutor
My reboot took a long time - in the end (over an hour) I had to turn it off, then it booted fine.
Also, has anyone tried uninstalling an app? I lose Dashboard when I try to uninstall some apps, so you may wish to enable ssh before trying.
viewtopic.php?f=153&t=79147
