Afiorai
Dec 22, 2014Aspirant
RN314 Upgrade From 6.2.0 to 6.2.1 No Problems
This is just to supply a bit of visible feedback for anyone still waiting to update. I have an RN314 and applied the update to OS6 6.2.1 from 6.2.0 on 21 Dec, 2014 and so far all is normal. No iss...
Afiorai
dsnpevl wrote: Did you already reboot after upgrading? That were the problems started for me.
Yes. To add to the info, I pressed the "Upgrade" button on the FrontView UI to start the upgrade then selected the reboot option afterward. The NAS rebooted and connections were re-established.
So, in other words, I didn't do anything special with the process.
