cleveland_rocks's avatar
Jul 03, 2020
RN314 won't power up
This morning (3 July 2020), my Netgear RN314 did not power up as usual. It is a 4 disk system running OS 6 with the latest firmware. I tried changing the outlet for the external power supply brick, a...
  • Sandshark's avatar
    Sandshark
    Jul 06, 2020
    It's actually a separate RAID with a separate set of partitions, but I think that's what you meant. fdisk  -l will show you all the partitions.  If you have more than one drive size or have ever upgraded from smaller drives without an OS re-install, the main BTRFS volume will span more than one RAID "layer".
ProSupport for Business
