metapaso
Nov 14, 2015Apprentice
RN316 Front Panel Buttons extremely sensitive - anyone else having trouble?
Hi all, On my RN316 I'm having a lot of trouble with the front panel buttons. They are extremely sensitive, such that it's hard to press any single button. When I press one, usually at least on...
- Nov 19, 2015
Hello metapaso,
This maybe a HW concern. It is best you contact support center.
Regards
JennC
Nov 19, 2015NETGEAR Employee Retired
Hello metapaso,
Regards
- metapasoNov 19, 2015Apprentice
Thanks. Actually I'm in the middle of some other trouble that Netgear Engineering is handling and in the process they issued and RMA for this front panel button issue.
I will mark this as solved because definitely it's an issue...sometimes the buttons lock up and are unresponsive.
Damon
