A_S_W
Oct 26, 2019Aspirant
RN316 "No IP Adress"
It's been working fine for some years now but when I got home some days ago it said "No IP Adress" on the display and it's not possibly to find it. The FW is 6.9.4. I rebooted it, I reinstalld the OS...
JohnCM_S
Oct 26, 2019NETGEAR Employee Retired
Hi A_S_W,
Welcome to the Community!
You may check if there is any LED activity on the NAS Ethernet port as well on the router or switch where the NAS is connected.
If you have not tried it yet, you can also try using a different port on the router or switch. You can also try using a different Ethernet cable.
- A_S_WOct 26, 2019Aspirant
I've tried different cables and ports but there's no LED activeties.
