A_S_W
Oct 26, 2019Aspirant
RN316 "No IP Adress"
It's been working fine for some years now but when I got home some days ago it said "No IP Adress" on the display and it's not possibly to find it. The FW is 6.9.4. I rebooted it, I reinstalld the OS...
A_S_W
I removed the discs and tried again, but there's still no IP adress. If I'll do the USB Recovery should it be done with the discs inserted or not? Is FW 6.10.2 the one too install or do you recomend another version?
Sandshark
Oct 27, 2019Sensei - Experienced User
I don't think it matters. Note that if you do recovery to a newer OS version than is currently loaded in your NAS, it will update the OS on the drives after it re-boots with the drives installed.
