DaveRuk
Aug 05, 2019Star
RN422 connection log, what are those entries?
As I was on the admin page of my RN422, checking on status of some NAS>NAS backups, I found myself looking in the connection logs also. There's not a great level of detail there but there are a fe...
- Aug 06, 2019
ReadyCloud does use Amazon hosting.
Aug 05, 2019Guru - Experienced User
Likely ReadyCloud - do you have that enabled?
DaveRuk
Aug 06, 2019Star
Sorry I should have mentioned I do use ReadyCLOUD. I'd assumed Netgear were using Amazon hosting services, but wanted to check to see if anyone could confirm that is the reason behind those log entries. Like many I'm sure, I don't like seeing connections that I am unfamiliar with.
- StephenBAug 06, 2019Guru - Experienced User
