astro76
Aug 04, 2018Aspirant
RN42200 Keeps telling me I have trojans in many files,
Sorry, my model number is RN42200, I couldnt find it in the list.
About three days ago I started getting allerts from it telling me I had infected files with a trojan. I deleted the two it tol...
- Aug 06, 2018
Just went ahead and did a factory reset.
Malwaerbytes ran test on the files and said they werefalse positive and felt something was going on with my nas becasue it wasnt updating do to the router issue.
So did a factory reset and moving on.
Thank you all for your help.
astro76
It looks like all the alerts are coming from files with Malwarebytes .exe.
I also get an alert saying the NAS antivirus fails to update.
- StephenBAug 04, 2018Guru - Experienced User
Have you scanned the NAS shares on a PC?
- astro76Aug 04, 2018Aspirant
I dont have any. I just drop and drag the files I want on to it. I open the batch file I made to access it and then put what files I want in it.
- StephenBAug 05, 2018Guru - Experienced User
I'm a little confused here. You mentioned Malwarebytes earlier, and that is a PC malware scanner. The NAS has it's own antivirus service, and it sounds like you have that turned on - and that it is the NAS software that is generating these alerts. You also mention that NAS antivirus isn't updating.
Do I have the NAS bit correct? Or is software on your PC (or Mac) detecting the trojans? How does Malwarebytes fit in?
The first thing I'm trying to sort out is whether the files are actually infected, or if the detection is false. The simplest way to do that is install an Antivirus package on the PC that can scan a network share - first scanning the PC itself, and then scanning one of the shares. I think the free version of Avast can scan a network share, but I am not certain. You might need to mount the share as a network drive letter though, if that's the case we can help you do that if needed.
