astro76
Aug 04, 2018Aspirant
RN42200 Keeps telling me I have trojans in many files,
Sorry, my model number is RN42200, I couldnt find it in the list.
About three days ago I started getting allerts from it telling me I had infected files with a trojan. I deleted the two it tol...
- Aug 06, 2018
Just went ahead and did a factory reset.
Malwaerbytes ran test on the files and said they werefalse positive and felt something was going on with my nas becasue it wasnt updating do to the router issue.
So did a factory reset and moving on.
Thank you all for your help.
Aug 04, 2018Guru - Experienced User
Have you scanned the NAS shares on a PC?
astro76
I dont have any. I just drop and drag the files I want on to it. I open the batch file I made to access it and then put what files I want in it.
- StephenBAug 05, 2018Guru - Experienced User
I'm a little confused here. You mentioned Malwarebytes earlier, and that is a PC malware scanner. The NAS has it's own antivirus service, and it sounds like you have that turned on - and that it is the NAS software that is generating these alerts. You also mention that NAS antivirus isn't updating.
Do I have the NAS bit correct? Or is software on your PC (or Mac) detecting the trojans? How does Malwarebytes fit in?
The first thing I'm trying to sort out is whether the files are actually infected, or if the detection is false. The simplest way to do that is install an Antivirus package on the PC that can scan a network share - first scanning the PC itself, and then scanning one of the shares. I think the free version of Avast can scan a network share, but I am not certain. You might need to mount the share as a network drive letter though, if that's the case we can help you do that if needed.
- astro76Aug 05, 2018AspirantYes you have the NAS bit correct. It's the antivirus thats detecting the trojans. And the Antivirus in the NAS wouldnt update and it is on. I figured out I was having router issues because my printer and security cameras were kicked of line. I power cycled the router and it brought those on line so Im guessing that was the issue there.The antivirus is pointing almost all or all detections to a Malwarebytes file.And it seems it only starts detecting them when I access the NAS.I have at this time copied files over to an external hard drive and ran Malwarebytes and G Data on the them and nothing was found. But I will try Avast and see what I come up with.Right now I'm getting some of the files ready for Malwarbytes to check out. They asked for them in a protected Zip file.I think I can map a network drive if needed but will ask for your help if I can't.So if they are false positives , why all of a sudden now after the files have been sitting in there awhile? And what would cause that?Thank you for you time and help, I really appreciate it.And I guess I do have some share files, I set readynas up on m sisters laptop so she could upload pictures to it. I scanned them and nothing was found.
- astro76Aug 06, 2018Aspirant
