dbreiny1
Dec 16, 2016Aspirant
RN516 - Unable to remove sickbeard directory after application removal
RN516 (6.5.0) Today I removed the applications SABnzbd and SickBeard. First I removed SAB and it went as expected without issue. Next I removed SickBeard and I steted Canot remove application, ...
FramerV
Dec 17, 2016NETGEAR Employee Retired
Hi dbreiny1,
Our engineers might be able to help you further on this but if your ReadyNAS is out of the 90-day support; you will be asked to pay for a contract or a per-incident support fee.
We can also wait for someone in the community to give us some commands to remove it from the UI.
bedlam1
Dec 17, 2016Prodigy
dbreiny1You could try going at it with Midnight Commander http://ftp.midnight-commander.org/mc-4.8.18.tar.xz
More info at Midnight-Commander
- dbreiny1Dec 19, 2016Aspirant
Thanks for the tip on Midnight Commander, for now I am going to hold off. I guess I was assuming there were some BTRFS commands I could use to check what the issue is and correct it (like fsck). Hopefully I can get a response from mdgm-ntgr or one of the other tech's with some advice/assistance.
