wolfgangcc
Aug 02, 2017Aspirant
RN516 stuck at "Retry Restart" on LCD
Rebooted RN516 after moving it between shelves, on startup it gets stuck and gives me a "Retry Startup" on the LCD. RAIDar locates the device and gives me a "Management service is offline". Tried res...
- Aug 06, 2017
Your 4GB root volume was full with a 2.4GB Photos folder. I've copied this to your home share for the admin user.
It's important to configure apps etc. to store data on the data volume.This is not an issue which a firmware update would have resolved, so trying USB Boot Recovery would have been pointless.
Aug 03, 2017Guru - Experienced User
Have you tried power-cycling the NAS?
wolfgangcc
Aug 03, 2017Aspirant
Yes, it will reboot, go though about 83% and then i start seeing services names come up on the screen and then it stops altogether and says retry restart.
- JennCAug 03, 2017NETGEAR Employee Retired
Hello wolfgangcc,
How about turning off the NAS and reinsert the disks to their respective bays then power it back on?
- wolfgangccAug 03, 2017Aspirant
So i gave that a try and it booted back up to a Retry Restart within 30 secs.
So if I try reloading the OS...is there anyone who has a known good USB drive brand/size that works, tried this once a year ago and was unsucessfull with the USB drives i had.
