jah313
Nov 02, 2016Tutor
RN516 Stuck Booting...Updating FW (FW 6.6.0)
I have 2 identical NAS516's and upgraded them both yesterday from 6.5.1 to 6.6.0. One of them upgraded with no problem and the other is now stuck (about 18 hours) saying "Booting... Updating FW". I C...
- Nov 03, 2016
Hi jah313,
It appears the issue you have described requires assistance from the engineers and/or higher tier who can remote in to the NAS and fix this from the backend. It shows on your records that you still have chat support warranty, I suggest contacting support center and can get one of the engineers take a look at it.
mdgm-ntgr
Nov 02, 2016NETGEAR Employee Retired
See what happens if you do a cold boot.
jah313
Nov 02, 2016Tutor
Do you mean manually power it down and restart it?
- jah313Nov 02, 2016Tutor
So I rebooted and it is doing the same thing!
- FramerVNov 03, 2016NETGEAR Employee Retired
Hi jah313,
- jah313Nov 03, 2016Tutor
Thanks FramerV I will get in contact tomorrow!!!
