jah313
Nov 02, 2016Tutor
RN516 Stuck Booting...Updating FW (FW 6.6.0)
I have 2 identical NAS516's and upgraded them both yesterday from 6.5.1 to 6.6.0. One of them upgraded with no problem and the other is now stuck (about 18 hours) saying "Booting... Updating FW". I C...
- Nov 03, 2016
Hi jah313,
It appears the issue you have described requires assistance from the engineers and/or higher tier who can remote in to the NAS and fix this from the backend. It shows on your records that you still have chat support warranty, I suggest contacting support center and can get one of the engineers take a look at it.
jah313
Nov 02, 2016Tutor
So I rebooted and it is doing the same thing!
FramerV
Nov 03, 2016NETGEAR Employee Retired
Hi jah313,
- jah313Nov 03, 2016Tutor
Thanks FramerV I will get in contact tomorrow!!!
- SuperJTFeb 19, 2017Aspirant
I'm having the exact same problem that jah313 is having. Im unable to open a support case currently because chat is down, so if anyone can shoot me the resolution to this I'd really appreciate it.
- mdgm-ntgrFeb 19, 2017NETGEAR Employee Retired
Did you try rebooting the system?
