mattmarlowe
Aug 03, 2016Guide
RN516 X-RAID Conversion RAID6 or RAID10?
I have a RN516 currently setup in default XRAID mode that was originally setup with all 2TB disks many years ago. All but one of those disks were upgraded last year to 4TB. In the next week, the la...
Anonymous
Aug 04, 2016Actually, a RAID10 can be vertically expanded, if all the HDDs are upgraded (one by one). Instead of creating a secondary RAID array, the primary RAID array will be "extended". I have tested it (though I'm not going to post the same detailed info as I did on X-RAID).
That's the way Flex-Raid handles Vertical Expansion.
On a 516, both RAID6 and RAID10 must be created using Flex-RAID, which require disabling X-RAID and destroying the volume. You can follow StephenB advices.
