Grasshopper1
Feb 24, 2012Aspirant
RND4000v2 Dlna Not Working
Hi Guys just throwing it out there, i have the V2 with Arm 5.3.3 its been replaced with a new unit for the same reason but i am unable to get the DLNA working for more than about 15 seconds before it ...
Grasshopper1
Feb 26, 2012Aspirant
Thanks for your reponse i atleast have access via the droid cheers as for the dlna side still no workie, i have done another system factory the media folder in audio video have several files in them and i still get the same problem here is whats in the log cheers
[2012/02/25 23:12:50] minidlna.c:894: warn: Starting ReadyDLNA version 1.0.20.2.
[2012/02/25 23:12:50] minidlna.c:920: warn: Creating new database...
[2012/02/25 23:12:51] minidlna.c:985: warn: HTTP listening on port 8200
[2012/02/25 23:12:51] minidlna.c:997: warn: TiVo support is enabled.
[2012/02/25 23:12:51] scanner.c:719: warn: Scanning /c/media
[2012/02/25 23:12:51] scanner.c:790: warn: Scanning /c/media finished (0 files)!
[2012/02/26 17:23:34] minidlna.c:894: warn: Starting ReadyDLNA version 1.0.20.2.
[2012/02/26 17:23:34] minidlna.c:985: warn: HTTP listening on port 8200
[2012/02/26 17:23:34] minidlna.c:997: warn: TiVo support is enabled.
[2012/02/26 17:26:45] minidlna.c:894: warn: Starting ReadyDLNA version 1.0.20.2.
[2012/02/26 17:26:45] minidlna.c:985: warn: HTTP listening on port 8200
[2012/02/26 17:26:45] minidlna.c:997: warn: TiVo support is enabled.
[2012/02/26 17:39:01] minidlna.c:894: warn: Starting ReadyDLNA version 1.0.20.2.
[2012/02/26 17:39:01] minidlna.c:985: warn: HTTP listening on port 8200
[2012/02/26 17:39:01] minidlna.c:997: warn: TiVo support is enabled.
[2012/02/26 20:07:07] minidlna.c:894: warn: Starting ReadyDLNA version 1.0.20.2.
[2012/02/26 20:07:08] minidlna.c:985: warn: HTTP listening on port 8200
[2012/02/26 20:07:08] minidlna.c:997: warn: TiVo support is enabled.
[2012/02/26 20:08:48] minidlna.c:894: warn: Starting ReadyDLNA version 1.0.20.2.
[2012/02/26 20:08:48] minidlna.c:985: warn: HTTP listening on port 8200
[2012/02/26 20:08:48] minidlna.c:997: warn: TiVo support is enabled.
[2012/02/26 20:10:21] minidlna.c:894: warn: Starting ReadyDLNA version 1.0.20.2.
[2012/02/26 20:10:21] minidlna.c:985: warn: HTTP listening on port 8200
[2012/02/26 20:10:21] minidlna.c:997: warn: TiVo support is enabled.
[2012/02/26 20:10:30] minidlna.c:153: warn: received signal 15, good-bye
[2012/02/26 20:10:31] minidlna.c:894: warn: Starting ReadyDLNA version 1.0.20.2.
[2012/02/26 20:10:31] minidlna.c:985: warn: HTTP listening on port 8200
[2012/02/26 20:10:31] minidlna.c:997: warn: TiVo support is enabled.
