Grasshopper1
Feb 24, 2012Aspirant
RND4000v2 Dlna Not Working
Hi Guys just throwing it out there, i have the V2 with Arm 5.3.3 its been replaced with a new unit for the same reason but i am unable to get the DLNA working for more than about 15 seconds before it ...
Grasshopper1
Feb 27, 2012Aspirant
dl vlc direct connected raidar found ok tryed to connect via stream option in vlc with no luck
OK so i got a direct connection to the samsung tv, no problems through the switch, but as soon as the router got reconnected then bang its gone,,, thanks so much so i just have to now chase down whats doing it but the rescan was brilliant thanks...........
Ok Problem solved, Is the Tivo box, disconnect it and it works perfect thankyou very much!! Ledgend :D
Now i just have to figure out how to keep the tivo connected to the network without interfearing with the nas's dlna... :roll:
