tdslaw
May 27, 2018Follower
RND4210 v1 wont power on
Cannot Power on
ReadyNAS NV +/1100 Series
RND/RNR 4000 series
model = RND4210
serial number = 23J31171001A9
MAC # E091F5F2AB47
Hello ReadyNAS support :
I have owned my R...
Sandshark
May 27, 2018Sensei
Assuming you verified the outlet has power (UPS didn't fail), chances are something in the NAS other than the button itself has died. Most likely the power supply, but perhaps something else. Since it happened at power-up, the data volume is likely intact. You could remove the drives (labeling order for re-installation) and see if it powers up empty. If it will, one drive may be dragging it down.
There are a lot of different ways to recover the data from the NAS. The preferred one is from your backup which, as a business device, it should most definately have had. But assuming that you don't have one, you could move the drives to a compatible chassis (ONLY another NV/NV+ V1), replace the power suppy (and hope that's the problem), use a standard ATX supply with a special adapter externally to power the NAS while you recover the data, or move them to a current model and (with paid help from Netgear), recover the data to an external device.
Buying a used NV/NV+ is a bit of a gamble, as it will likely be no younger than yours. If you were to do so, you should consider it a temporary thing to move the data to a new NAS. You then might consider using it as a backup.
