Donkoe
Aug 16, 2022Aspirant
RNDP2000 will not stay on
My RNDP2000 will turn on, lights on network interface, but turns off after about 1.5 minutes. I am unable to keep on long enough to troubleshoot. Ideas?
Aug 17, 2022Guru - Experienced User
What firmware is it running?
Was the onset of this issue sudden, or did you sometimes have issues with it locking up before?
Sandshark
Aug 17, 2022Sensei
Can you grab the log file before it shuts down to see if it's shutting down under control (shutdown is logged) or you ju st see the next power-on without a prior shut-down?
If it's uncontrolled, then a power issue could be it, it could be bad RAM, or it could be a (probably erroneous) indication of over heating.
If it's controlled, hopefully the logs will be informative as to why.
If it's a power issue, a new power brick might help, but I wouldn't put a lot of hope in that.
- DonkoeAug 17, 2022Aspirant
Thank you for your reply.
i am not able to get into it (might be a bad process on my part).I have it plugged into my network. I see the IP on my router, but I am unable to get to it via a BROWSER interface.
Is there some other preferred method.
As an aside, I was able to see the data on the drive via RECLAIM software, so I know the data/drive is good. It is just the devide. RAM is a good thought. It was VERY DUSTY inside. I cleaned it out, but it could still THINK there is a heat issue.If there is a good process for seeing logs, or consoling in, please advise.
Thank you again!
Don
- StephenBAug 17, 2022Guru - Experienced User
Again, what firmware is it running? 4.2.x or 6.x.x.????
I am unsure how to determine the firmware as I am unable to console in.
