rtryp
Aug 02, 2024Follower
RNDP6000 - Volume C - Offline
Hello- Currently running a ReadyNas Pro 6- RADiator 4.2.31 So I had 6 3tb drives running in the X-Raid array configured for dual-redundancy. I had disk 3 fail. I didn't have another 3tb drive on ha...
Aug 02, 2024Guru - Experienced User
It might be too late to sort out what happened, but I still suggest downloading the full log zip, and looking in there.
You could try RAID recovery software such as R-Studio:
This runs on Windows, and would require a USB enclosure or enough docks to connect the disks to the PC. You'd also need enough storage to offload the data.
