pbsnpr
Dec 07, 2021Tutor
RNDP6000-100 CPU/RAM upgrade suggestions
I have a ReadyNAS Pro Business Edition, I believe it is the older model (RNDP6000-100) bought in 2008. I bought it with a RAM upgraded to 3GB (I think DDR2 DIMM). It currently has six, 1TB drives. ...
- Dec 07, 2021
Either processor is fine. The difference in performance is minimal, but so is the price difference these days. Both can be had for under $10 on eBay. I agree with StephenB, go for the 4GB total RAM. It's also dirt cheap on the used market. CL4 memory will give a minor speed boost over more common CL6, and isn't that much more today. But you'd have to replace it all to get that increase.
Dec 07, 2021Guru - Experienced User
pbsnpr wrote:
Q2: should I keep the 2GB ram and swap the 1GB with another 2GB?
I would. Plex can use quite a bit of memory.
Sandshark
Dec 07, 2021Sensei - Experienced User
