pbsnpr
Dec 07, 2021Tutor
RNDP6000-100 CPU/RAM upgrade suggestions
I have a ReadyNAS Pro Business Edition, I believe it is the older model (RNDP6000-100) bought in 2008. I bought it with a RAM upgraded to 3GB (I think DDR2 DIMM). It currently has six, 1TB drives. ...
- Dec 07, 2021
Either processor is fine. The difference in performance is minimal, but so is the price difference these days. Both can be had for under $10 on eBay. I agree with StephenB, go for the 4GB total RAM. It's also dirt cheap on the used market. CL4 memory will give a minor speed boost over more common CL6, and isn't that much more today. But you'd have to replace it all to get that increase.
pbsnpr
Dec 07, 2021Tutor
I just read the entire 12 pages of More on CPU specs of the ReadyNAS Pro
I don't know how to check which CPU mine has but I guess it's E2160 (1.8GHz).
I think I will go with E7600 as they all seem to be around $10 on ebay; and 8GB (2x4GB) total RAM.
As for the RAM upgrade, I need DDR2 PC2-6400 DIMM 800mhz, correct?
thanks
