pbsnpr
Dec 07, 2021Tutor
RNDP6000-100 CPU/RAM upgrade suggestions
I have a ReadyNAS Pro Business Edition, I believe it is the older model (RNDP6000-100) bought in 2008. I bought it with a RAM upgraded to 3GB (I think DDR2 DIMM). It currently has six, 1TB drives. ...
- Dec 07, 2021
Either processor is fine. The difference in performance is minimal, but so is the price difference these days. Both can be had for under $10 on eBay. I agree with StephenB, go for the 4GB total RAM. It's also dirt cheap on the used market. CL4 memory will give a minor speed boost over more common CL6, and isn't that much more today. But you'd have to replace it all to get that increase.
pbsnpr
Dec 15, 2021Tutor
thanks for the info. I bought the same synology for my personal files and retiring the Pro BE as a media server.
from your post:
- I didn't know I could use a Xeon processor. I am curious if Xeon can be installed on the Pro BE motherboard.
- using your second Pro 6 as a synology backup, how are you doing this? I thought you would need a second synology to use their backup app (hyper backup?). maybe it is only if you want to backup to off-site...?
- also, your RAM recommendation of Crucial CT51264AA667.M16FC, it appears to be a 667mhz stick. do you see any performance issues or is 800mhz unnecessary?
thanks again!
MCEComputers
Dec 15, 2021Apprentice
from your post:
thanks again!
It is my understanding that the newer versions of the Pro 6 BE can be upgraded to the Xeon X3230 (and others). You would have to check the model number and bios version to find out and I do not recall the steps to do this.
I use the backup system on the Pro 6 to pull backups from the Synology DS-920 using rsync. Hyper Backup on your Synology can send backups to your ReadyNAS. I used Hyper Backup for a while but I prefer being able to see the actual files on the backup destination after the backup completes and to be able to copy or move those files to another destination without have to use an app. If Hyper Backup is used to make your backups, it must also be used to restore files if/when they are needed. All three of my NAS are in my home office so no off site backups.
The Crucial RAM is 667MHz, but I can't say how that affects perfomance vs 800MHz. One of my Pro 6 was purchased with the 8gb, 667MHz RAM already installed so I bought the same RAM since I knew it would work and I found it for way cheaper that what I was seeing for prices, even for 2gb sticks. The other Pro 6 I upgraded from 1gb to 8gb before I actually ever used it. For my use I don't think the difference from 667MHz to 800MHz would even be noticeable.
- SandsharkDec 15, 2021Sensei
I know of no dual-core Xeon processor that will give you better performance in a 6-bay Pro than a Core2 E7600. Quad core brings a whole new issue into the discussion because of too much heat dissipation for the stock cooling system. The X3230 is only 2.66MHz, BTW, where the E7600 is 3.06.
The original ProBE/Pro Pioneer processors only ran the FSB at 667MHz, and the RAM was so matched. But if you upgrade to a CPU with 800MHz capability (the highest the motherboard will go), then you will see some improvement with 800MHz RAM.
- MCEComputersDec 15, 2021Apprentice
For me, the Xeon X3230 seemed to improve the performance of the NAS over the E7600, even at the slower clock, possibly due to my use case.
I am recording videos and still pictures from three security cameras. Two of the cameras send the videos/pictures directly to the NAS via ftp. The third camera uses Synology Surveillance Center to capture the video stream and send it to the ReaydNAS via CIFS.All three cameras are recording videos 24/7 in 5 minute chunks. The two ftp cameras also take motion detection pictures.
With the E7600 CPU, there was a noticeable delay when playing back the recorded videos. With the X3230 CPU that delay has been reduced to less than half of what is was.
ReadyNAS shows the E7600 cpu running at an almost constant 39c/102f on balanced fan control.
ReadyNAS shows the Xeon X3230 with 2 core temperatures(for a quad core processor) running at about 35c/95f and 37c/99f and a CPU temp at 40c/104f on cool fan control.
- pbsnprDec 17, 2021Tutor
thanks MCEComputers & Sandshark the information you guys provide are very informative.
I need to study on how to enable synology backup using rsync.
Anyway, I was able to replace the E2160 1.80ghz (dual-core SLA8Z) with E7600 3.06ghz (core 2 duo SLGTD). I do worry about the temperature issues, but I am unable to find a CPU heatsink/fan that could fit without modification.
I was not able to upgrade the RAM because they are either expensive or unavailable, so I am stuck with 3gb for now. (I am searching for Crucial CT51264AA667.M16FC or Patriot PSD28G800K 2 x 4GB).
I may need to upgrade the hard drives soon. Mine are 6 x 1TB and using XRAID I barely have enough space for my use. I may start with 4 drives for now to reduce the heat.
How do I access cpu temp info? via SSSH?
- MCEComputersDec 18, 2021Apprentice
Temperature should not be an issue with the stock fan and heat sink with the E7600 cpu. I did not like the noise from the stock fan(s) so I replaced them with these:
https://smile.amazon.com/gp/product/B00E7FSR6S/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
https://smile.amazon.com/gp/product/B0083A0BIA/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
Haven't seen a big change in cpu temps, maybe 2 degrees (c).
You can see the current temperatures under the System tab -> Performance. Scroll down the page to see a chart of temperature over time.
4gb ddr2 sticks that work with the Pro 6 can be difficult to find and are usually expensive. The 2gb sticks are much more available at a decent price point. You can pick up one of the 2gb sticks to bump your machine up to 4gb total and try it like that while you are waiting for a deal on the 4gb sticks. You may find that Plex works fine with 4gb, depends on how many users you have accessing Plex and if you have a need to transcode files on the fly.
To enable rsync on Synology: Control panel -> File Services -> rsync tab
