Ezechias
Apr 12, 2016Aspirant
RNDU2000 admin page does not load after factory reset
The admin page of the NAS does not load after a manual factory reset, by pressing the combination keys on the chassis. A laptop connected directly to the NAS displays "http://192.168.168.168/admin", ...
Apr 14, 2016Guru - Experienced User
You could try a direct connect.
Set the PC ethernet configuration temporarily to
IP: 192.168.168.100
subnet: 255.255.255.0
Gateway: 192.168.168.1
Connect the NAS ethernet cable directly to the PC (not the router or switch).
Then try https:/192.168.168.168/admin
JennC
Apr 19, 2016NETGEAR Employee Retired
Hello Ezechias,
We’d greatly appreciate hearing your feedback letting us know if the information we provided has helped resolve your issue or if you need further assistance.
If your issue is now resolved we encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution.
The Netgear community looks forward to hearing from you and being a helpful resource in the future!
