tijgert
Oct 25, 2014Guide
RNDU6000 won't expand from 5x6TB to 6x6TB X-Raid2
My RNDU6000 runs (ran) 4.2.26 fine with 5 WD Red 6TB drives in X-Raid2. I added a 6th 6TB drive about 68 hours ago and the system started expanding. Now that it has finished it says 'expansion fai...
mdgm-ntgr
Oct 25, 2014NETGEAR Employee Retired
With 4.2.x you can't expand a volume past 16TB. You have to do a factory reset with that capacity in place. That's why the expansion failed.
You will need to do a factory reset to get a higher volume capacity.
OS6 doesn't have this expansion limitation on x86_64 hardware.
