dlargo
Feb 01, 2018Aspirant
Rogue Shares
I have a unique issue. I recently purchased a 214 4 Bay device and everything is working great so far...but for some reason under windows explorer I see 3 shared folders that do not exist on the NAS...
Feb 01, 2018Guru - Experienced User
I suspect you have ReadyDLNA enabled, and are looking at the NAS as a "media device" in the network list.
ReadyDLNA categorizes by media type, and those categories will show up as "folders" that aren't shares.
dlargo
Feb 02, 2018Aspirant
Thanks for the reply.....it is a default system with only the name of the unit changed. I am viewing it through the windows explorer window under the network.
Danny
- SandsharkFeb 02, 2018Sensei - Experienced User
ReadyDLNA is enabled by default. If the device you see under Network has the Netgear stylized N logo, then you are looking at it as a media device, even though you may not realize it.
- StephenBFeb 02, 2018Guru - Experienced User
Windows Explorer categorizes the network list and the NAS is often listed in more than once (in different categories). With Windows 10, the DLNA server in the NAS will show up as a "media device". The NAS also will frequently show up as a "storage device" and as a "computer".
What happens when you click on those instances depends on Windows. With the Media Device, you are seeing ReadyDLNA's organization of your media (music, video, photo, ...) - they are shown as folders, but they are not.
