delange
Nov 29, 2013Tutor
Rsync backup fails
I’m trying to setup an rsync backup job from my ReadyNAS NVX to a Wandboard running Fedora 19. I have configured the rsync daemon on the Wandboard and I’m able to successfully test the connection fro...
Nov 30, 2013Guru - Experienced User
set the "set ownership" checkbox and then click apply at the bottom right. After a while you will see a popup telling you it has completed. if you miss it, you will see the completion in the log.
