PNGum
Jul 22, 2021Follower
RSYNC backup tips
If someone has two ReadyNAS OS6 devices, any tips on setting up RSYNC backups on ReadyNAS #2 to "pull" from ReadyNAS #1 to ReadyNAS #2? Any tips for the RSYNC "Advanced" tab? If someone has 10 sh...
Sandshark
Jul 22, 2021Sensei
If you don't want the backup in a folder within the share, go in and edit the destination after you've created the job and put a forward slash ("/") there for the path, which is typically empty.
Jul 22, 2021Guru - Experienced User
You don't need to do that for pull backups, just for push.
