arnie1
May 18, 2013Aspirant
Rsync Fails
Hi All, I got a problem with my Rsync on my ReadyNas NV+ - I have 2 NAS's at home (one readynas and another server). I was attempting to modify a previously created rsync job but after saving it n...
May 18, 2013Guru - Experienced User
I created a new rsync backup job on 4.1.9 earlier this week successfully.
Looking at my log details, all my logs have the double colon -so I don't think that is your problem. Maybe check permissions on the source and destination, and also the credentials you are using in the backup job?
One difference is that the duo v1 is the destination, my pro is the source.
BTW you can put the slash in yourself if you think you need it - just add it to the path name.
